Emissions ...HELP!
Old 08-28-2008, 06:49 PM
dv3
dv3's Avatar
Default Emissions ...HELP!
so i bought a 95 gt ...
it failed the first emissions test for high hc ...limit is 1.2...my car was 2.6
so i added some bg 44k, new plugs and wires, and and oil change...then drove it 100 miles ...it failed the test again at a scorre of 5.0 this time
if it was clogged cats wouldn't it set off the o2 sensor and check engine light?
could it be because the gas tank was about half full a the filler tube for the tank is leaking ?
any help is appreciated
thanks
dv3 is offline
Old 08-28-2008, 09:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you need to run the complete tank with bg 44k through it, do not take test with it still in the tank it will affect emissions
mjr46 is offline
Old 08-28-2008, 10:31 PM
dv3
dv3's Avatar
well the guy at checker said that i had to test while it was still in the tank ?
....even though i had to buy it at napa
why do you say run it out of the tank first?
dv3 is offline
Old 08-28-2008, 11:51 PM
mstngsule68
mstngsule68's Avatar
run it through, and when you go back put a full tank of 93 in....im trying to remember why i failed with my s10 i had...but i changed the cat and it pass with flying colors. i think hc was one..
mstngsule68 is offline
Old 08-29-2008, 06:52 AM
mjr46
mjr46's Avatar
The guy at checker should stick to doing what he was trained to do and that is sell parts not try and fix cars!!...the Bg 44k is an inernal fuel system and cumbustion cleaning agent that'll raise cylinder temps in order to perform it's duty = clean out carbon, trust me run the tank through and put fresh gas in but when a vehicle fails for hc's =hydrocarbons which are unburnt fuel molecules, it can often indicate a vehicle is running rich and also indicate a worn motor, make sure it has a fresh oil change and nocodes exist in the ecm that indicate a malfunction in the fuel management system, a simple koer test will tell you that
mjr46 is offline
Old 08-29-2008, 07:22 AM
dv3
dv3's Avatar
ok ill run out the bg 44k and fill it back up..(what about the leaking gas?how does that affect the test?)
and do a koer test...
any other suggestions before i go spend another $25 for emissions
dv3 is offline
Old 08-29-2008, 10:56 AM
mjr46
mjr46's Avatar
where is it leaking gas???
mjr46 is offline
Old 08-29-2008, 10:57 AM
dv3
dv3's Avatar
the seal between the filler neck and tank
dv3 is offline
Old 08-29-2008, 11:05 AM
FuzzyDiceRule
FuzzyDiceRule's Avatar
get a new one, theyre like 14 bucks from LMR or if you want it soon, 30 from a dealer
FuzzyDiceRule is offline
Old 08-29-2008, 11:07 AM
mjr46
mjr46's Avatar
that won't affect tail pipe emissions unless it were leaking all over the place so that the tail pipe monitor were picking up the fuel vapors, mine leaked there too, rust had set in!! had to clean it up and solder the areas that were leaking, now it's good as new
mjr46 is offline
Quick Reply: Emissions ...HELP!
