adjustable roller rockers
Old 08-29-2008, 12:52 AM
mstngsule68
mstngsule68's Avatar
give the company a call and tell them whats going on.. they might have heard this before and have a solution.
mstngsule68 is offline
Old 08-29-2008, 12:57 AM
tommiesgt
tommiesgt's Avatar
lol im thinking loc tite. I kinda thought that the rocker girdles were supposed to prevent this kind of problem...
tommiesgt is offline
Old 08-29-2008, 01:02 AM
mstngsule68
i thought rocker girdles just add strength to the rockers and valvetrain. i dont know about putting loctite inside of a motor. id just call the company
Old 08-29-2008, 06:56 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
loctite will be fine on the polyloc, although never had to do such
mjr46 is offline
Old 08-29-2008, 07:04 AM
tommiesgt
tommiesgt's Avatar
i dont think that the rockers are the problem i think its the special bolts that were needed to use the rocker girdles and im assuming they came with it but since i didnt put them on and there are no numbers or names on it whatsoever i have no idea who i would call. Think im going to try the loc tite though see what happens
Old 09-02-2008, 02:57 AM
mstngsule68
so....what happend?
Old 09-02-2008, 06:32 AM
AdderMk2
Banned
AdderMk2's Avatar
Originally Posted by tommiesgt
YEah i have been tightening down the allen then cranking the bolt down more and they still loosen back up,
this right here is why you are having problems... you are doing it wrong
remove the allen headed poly lock completely out of the adjuster nut. turn the (5/8 on mine) adjuster nut until you reach 0 lash, then give it an additional 1/4-1/2 turn. now screw the allen head poly lock down into the adjuster, and lock it down. remember... DO NOT LET the adjuster nut turn any further.
it sounds like you are doing it backwards
AdderMk2 is offline
Old 09-02-2008, 11:29 AM
tommiesgt
tommiesgt's Avatar
adder thats the was i started doing it and they were coming loose so i figured the poly lock would saty better if i got o lash then tightened the poly lock then did the quarter turn it would stay tighter but it didnt. So i went back to the way you said and used some lock tite and tightened the girldes as much as i could, been 2 days now and no noise so we will see...
cr620
10-03-2022 10:18 PM
Sixer4Life
10-12-2015 04:26 AM
UrS4
10-03-2015 06:23 AM
winner99
09-30-2015 07:04 PM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: adjustable roller rockers
