exhaust manifold
Try to do it without the header in. Inspect the threads to see if something is screwed up. But Iron heads are hard to screw up so just take your time and put some straight force on the bolt to see if it will go in straight.
Do you still have the h pipe in place? I had that problem, someone here told me I could install the new headers without removing the h-pipe. I had the same problem you are having. I disconnected the mufflers and moved the pipe back a inch or two and it all worked out fine
If its hooked to the H or X pipe unbolt it then bolt the header to the heads. Do yourself a favor and get yourself some locking header bolts.
Out of curiosity what headers are you attempting to install?
Very informative post Adder lmao
