a9s computer
Old 08-31-2008, 01:13 PM
jssblues
jssblues's Avatar
Question a9s computer
what is the difference between a9s computer and a9l,a9p?????????????
a9l=mass air 5-speed
a9p=mass air auto
a9s=???????????
jssblues is offline
Old 08-31-2008, 01:30 PM
dudeboy
dudeboy's Avatar
The differences will be minimal... to the point that you probably won't notice.
(same way you probably wouldn't notice the difference between A9L vs A9P)
I can look a little closer when I get home today...
jason
dudeboy is offline
Old 08-31-2008, 01:37 PM
jssblues
jssblues's Avatar
i just recently ordered the a9s cause i am converting to mass air...my current s.d.computer has a performance module, will it be compatable with the a9s?????
jssblues is offline
Old 08-31-2008, 01:44 PM
Joel5.0
Joel5.0's Avatar
A9S is the CA (emissions strict) for manual transmissions program code.... and nope, the SD ECM performance chip will not be compatible with any Mass Air ECM.
Joel5.0 is offline
Old 08-31-2008, 02:05 PM
jssblues
jssblues's Avatar
why cant i find out any info on this module??? it says performance module by superchip..
i try to lookup some info on it, hell i even have the part# but i cant even find that this thing was ever even made
jssblues is offline
Old 08-31-2008, 02:08 PM
jssblues
jssblues's Avatar
i know that a chip would not work but this is a module that goes in between the harness and computer, isnt that different???
jssblues is offline
Old 08-31-2008, 02:45 PM
Joel5.0
Joel5.0's Avatar
If the only way to change its programming is by having it "re-flashed" (no way to access system parameters via a laptop)....... it's a chip "encased" in a PWB substrate to connect to the ECM via the test port. Internal logic is different between ECM types.
Joel5.0 is offline
EZFEED
05-05-2016 08:54 PM
piotrek53
10-13-2015 06:54 PM
ChampInSD
10-02-2015 04:55 AM
firecoyote
09-27-2015 02:37 PM
mltdwn12
09-23-2015 08:54 AM
Quick Reply: a9s computer
