Brake Question
Brake Question
I plan to use the SSBC drum to disc upgrade on the rear. This comes all parts necessary including the master cylinder. On the front I want to just upgrade to the SVO 73mm calipers. I want to piece the front together as it will be cheaper than buying a kit. My rotors and pads currently have under 3k miles.
Now for the questions. I would assume my current front brake hoses will connect to the new master cylinder setup and want to know if the 87-93 front brake hoses are a direct fit to the SVO calipers? Are the SVO pads bigger than the 87-93 V8 pads? I currently have EBC RED ceramic pads and may switch to the HAWK ceramic pads if the SVO pads are noticibly bigger.
Thanks
Thanks
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
