Fuel pump and other wiring ?
I have an 88 lx. was originally a 4cyl.
I am needing the wiring diagram for the fuel pump. Since changing out the engine harness and computer the fuel pump will not prime when key is in ON position.
Next I need the wiring diagram for the neutral safety switch plug under the car, So I can wire it to a different tranny Or just a tip on how to bypass it so It wont be a problem.
thanks
Doug
thanks
Doug
all you really need to do to the relay under the driver seat is ground the one leg of the relay that the ecm controlled which was once ecm saw pip signal relay was grounded and for the nuetral saftey switch there will be fur wires loop the correct two together for start operation and the other two get connected to back up light switch , using a test light you should be able to figure out which ones are which
jaiidutch
09-14-2015 10:29 AM
