Replaced my heater core, still smells
I replaced my heater core on my 90 GT myself. I wiped and vacuumed as much of the anti-freeze residue as I could out of the evaporator case.
After I got everything back together, I still smell anti-freeze when the heater is on. WTF??
Have any of you guys used that dye in your coolant to find leaks? I'm considering giving it a shot.
When I bought the heater core from Autozone, the box was open but it looked fine - no damage so what the hell. Not sure If it's leaking, but the low coolant light came on twice now and I'm finding no leaks. Carpet/floormats not wet either.
Is the dye worth it? If I have to tear into the dash again I'm gonna ****!
I read too many bad things about the stock heater core failing. When I removed the old one it was rubbed right thru the side of the fins! Like it was rubbing agains the evaporator case.
The heater core from Autozone had the fins slightly below the endtanks. I felt that rubbing issue wouldn't be a problem again.
Replaced it about 3 weeks ago.....still smells like antifreeze when heat is on.
It's had the heater core disconnected for several years, so why would I still smell coolant?
The windows DO NOT fog up when the heat is turned on.
Anyhow, anyone tried the leak dye??
when a heater core fails all that moist antifreeze condenses inside all the vents, just cleaning the case often is not sufficent as it has coated the inside of the vents if let go long enough
Thanks for your reply mjr46-
Since I bought the car with the heater core bypassed I have no idea how long this was puking coolant all over.
Even though I wiped out the evaporator case I knew there was only so much I could reach.
From the sounds of it opf your reply, this smell is something that will not go away....bummer!
As far as replacing the heater core....It was not hard put VERY time consuming! The entire dash has to be removed and teh steering column has to be dropped, but not removed.
You also have to discharge your A/C system and disconnect a few A/C/ lines so you can pull the evaporator case away from the firewall to gain access to the heater core.
I haven't recharged the A/C yet.
Considering how bad my heater core was, I think I'll be installing new carpet soon!
