Speedometer problems
Old 09-07-2008, 10:24 AM
65coupe88hatch
65coupe88hatch's Avatar
ok so i did that test, and got 2 complete revolutions, so im assuming its a 2.73 gear. So with that knowledge i put the 16 tooth speedo gear and its way off.....with that said im assuming it has to be the speedometer cable or the speedometer itself....anyone agree?
65coupe88hatch is offline
Old 09-07-2008, 10:28 AM
Hicompression
Hicompression's Avatar
Ninja edit...nevermind.
Hicompression is offline
Old 09-07-2008, 10:34 AM
65coupe88hatch
Just thought of one more thing.....could the speed sensor be bad?
Old 09-07-2008, 11:10 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you don't have a speed sensor on an 86....it's all mechanical = drive gear/ assembley, cable and speedo head unit
mjr46 is offline
Old 09-07-2008, 01:52 PM
Timspony
SVT Section Moderator
Timspony's Avatar
does it have a speed sensor for the cruse control???
Timspony is offline
Old 09-07-2008, 03:05 PM
65coupe88hatch
no cruise control....so i bought and installed a new speedometer cable, with the 16 tooth gear and did nothing for it...any input what it can be?
Old 09-07-2008, 04:11 PM
mjr46
mjr46's Avatar
well most likely you have stock 2.73 gears and if the gear on the out put shaft inside the tranny is the correct one, I believe it should be yellow then the ONLY OTHER THING IT CAN BE IS THE SPEEDOMETER ITSELF!!!
mjr46 is offline
Old 09-07-2008, 04:16 PM
mjr46
mjr46's Avatar
oh and for 2.73 gears I believe 17 tooth is close to what you need on the drive assembley if you have it mated to the 7 tooth yellow gear on the output shaft, shine a light in the hole and see what color it is, cause if it's black it'll require a different combo as the black one on the output shaft is a 6 tooth
mjr46 is offline
Old 09-07-2008, 04:36 PM
65coupe88hatch
Yeah i know there are two different output gears, I have tried the 16,17,18,20,21 for awhile i drove with the 18 tooth in, i put the 20 in this afternoon and its the same as the 18 on my speedometer....i do believe the speedo has to be wrong. so with that said do you still want to sell that cluster? if so pm me when you read this.
Old 09-07-2008, 05:12 PM
mjr46
mjr46's Avatar
pm sent
mjr46 is offline
articman
06-21-2018 11:45 PM
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: Speedometer problems
