weird noises
weird noises
Every time i seem to take off i hear this real loud ticking noise on the right side, i can hear it from the driver side, the car is an auto, so i dont know what it could be. when i drive the car normal i dont hear it. Thanks for helping me
yep, its an exhaust leak, factory header gaskets are usually a paper-like material. so buy some copper ones or the aluminum headers gaskets and i would advice some locking header bolts, cause mine keep backing out, but i gaurantee thats your problem
also look around where the flange is, where the header and the H pipe connect and look to see if there is any black residue around the flange where the exhaust would be leaking by, because some times if the bolts are tighten up where one bolt is more tight then the other the flange will bolt up crooked, and cause a leak.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
