Temp gauge and tachometer not working . NEED HELP PLEASE!!!
Old 10-03-2008, 10:28 PM
92 5.0stang
92 5.0stang's Avatar
Default Temp gauge and tachometer not working . NEED HELP PLEASE!!!
The temp gauge doesnt work at all ? And all other gauges except the tach work. Any ideas why ?
The tachometer seems to not go any lower then 3000 RPM's . For example ill start my car it will go from 0 to 3000 and stay there unless i give it some gas until the engine actually gets past 3000 RPM's then it works but then it goes back down to 3000 it wont go any lower. And the engine is definatly not idiling at 3000 RPM's. Any ideas on what is wrong and what i can do to fix it ? oh also if im idiling ,and if i turn on any accessorys like the wipers or the headlights the RPM goes down alittle.And when i turn the engine off it goes back to zero.
92 5.0stang is offline
Old 10-03-2008, 10:46 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
sounds like the tach is bad, and as for temp gauge, try a new sending unit
mjr46 is offline
Old 10-03-2008, 11:00 PM
92 5.0stang
Where would i be able to get both?
Tivo304
08-28-2023 12:19 PM
Mobiusone stang
09-07-2015 08:46 PM
TimeLord101
09-04-2015 09:27 AM
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Temp gauge and tachometer not working . NEED HELP PLEASE!!!
