TIMING OUT BAD..pls HLP
#23
if it blows your finger out that means you have compression, valves closed. if you just feel air blowing out you very well could be on exhuast stroke.
if it did indeed blow your finger out, and you have all your wires hooked up correctly with everything in the correction position. have someone crank the motor for you and turn the dizzy until she fires up, you need to keep it running in order to time it.
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
