adjusting cluth in my 88gt
Old 10-20-2008, 04:51 PM
50foshow
50foshow's Avatar
Default adjusting cluth in my 88gt
Hey fellas i just installed a new tranny and clutch in my 88 gt and when putting it into reverse it does some grinding its like my clutch ant funny disingaging and i have some slop in the clutch pedel how do i adjust this problem i no their self adjusting is their anyhting else i can do. thanks
50foshow is offline
Old 10-21-2008, 04:52 PM
15austin
15austin's Avatar
You need to ditch that junk stock clutch quadrant and buy an aftermarket, adjustable one. There only like $60 on ebay. Money well spent, it beats grinding on your new trans.
As for your stock piece, you could try pulling up on your clutch pedal, it should click a couple times and that may help.
15austin is offline
Old 12-05-2008, 11:57 AM
DocKnotts
DocKnotts's Avatar
Yes, definitely buy an aftermarket one. Fix ya right up.
DocKnotts is offline
Old 12-05-2008, 12:58 PM
DocKnotts
DocKnotts's Avatar
Also, try this out and see if it works for you.
http://www.corral.net/tech/drivetrain/clutcha.htm
Old 12-05-2008, 09:18 PM
Jfsram
Jfsram's Avatar
I'll be the first to praise quality aftermarket quadrants but you guys make it sound like a stock set up will not enable you to engage reverse.
Pull the pedal up past it's normal position. This will initiate the ratchet mechanism and tighten up your cable. You should now have full disengagement.
Even with a fully disenaged clutch. Reverse will still grind if you don't let the disc stop spinning. You either need to wait about 3 seconds before you jam it in reverse or slip in it a forward gear, then engage reverse. Unless you have a 93 like me. Then you don't have to do either.
Jfsram is offline
cr620
10-03-2022 10:18 PM
baddog671
07-26-2016 01:20 PM
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
winner99
09-30-2015 07:04 PM
Quick Reply: adjusting cluth in my 88gt
