recurring transmittion problem + others....
Old 05-24-2005, 12:38 PM
miracles
miracles's Avatar
Default recurring transmittion problem + others....
1994 5.0
Trick Flow valve covers/intake manafold track heat, Mac cold air kit, Mac H-pipe exhaust, Motor Sport 3.75 ring & pinion, polution pump eliminator, Kirban fuel pressure regulator, professional TB 65 mm, Diablosport computer chip.
The transmission started slipping, so I had a new transmission put in.....but I don't think the guy knows Mustangs and I've been back about 5 times now for him to make adjustments. It's still clunking from first to second and I don't have the power I used to. The code that was coming up was 'excessive converter clutch slippage'. Today I found the original owner. He told me that a year before I bought the car he was having the same trouble and had a new transmittion installed and the converter clutch fixed.....now three years later and another new transmittion, I'm having the same problem. Does anyone have any thoughts?
Then, awhile ago, the check engine light came on. I got a new computer, but still the same codes. I checked the codes and I get the following numbers. How tied into each other do you think all of this is.....because I seem to be going round and round. One thing sends the computer into default and then I'm not sure if it effects the transmittion or not. I've tried it with and without the chip.
I'd love to keep this beauty, but I might have to trade it in for a new one if I can't figure this out relatively cheaply. If you'd like to help email me at richard@atvpro.com
The codes:
Fast Codes
113 Intake air temp signal high - ckt open
Continuous Memory
172 EGO not switching, lean exh - Bank 1
189 Cruise rich limit, Bank 2 still lean
628 excessive converter clutch slippage
miracles is offline
69Volunteer
09-30-2015 10:39 AM
marc954
09-29-2015 03:05 PM
marc954
09-25-2015 06:48 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: recurring transmittion problem + others....
