Need some advice for radiator and electric fans
Old 10-22-2008, 01:15 PM
FOUR EYE
FOUR EYE's Avatar
Default Need some advice for radiator and electric fans
Can anyone give me some advice on what setup would be the best way to go. I have an 85 GT with a 347 T-5, mini tubbed, etc... I am looking at the Be Cool Module setup and and Griffin rad with Spal fans. Are there any other combos out there worth looking at? Thamks...
FOUR EYE is offline
Old 10-22-2008, 01:16 PM
FOUR EYE
FOUR EYE's Avatar
mainly a street car, thanks...
FOUR EYE is offline
Old 10-22-2008, 01:20 PM
88BlueGT
88BlueGT's Avatar
Save yourself ALOT of cash and alot wiring with one of those spal fans and controllers. GO with a fluidyne or radiator of your choice, get a Taurus fan and hook up a high/low through a switch in the center (ashtray switch or something). Easiest way to do it IMO. the Taurus fans push ALOT of air but pull alot of amps as a downside. And if you want it to look nice you just make some brackets for the fan to fit the radiator like this...
88BlueGT is offline
Old 10-22-2008, 01:31 PM
FOUR EYE
FOUR EYE's Avatar
thanks, good idea. I alos heard of people using firebird dual fans.
FOUR EYE is offline
Old 10-22-2008, 01:34 PM
88BlueGT
88BlueGT's Avatar
hmmm never heard of firebird fans but Im sure people do it lol. The whole setup brand new will run like $550 bucks including the fluidyne radiator, taurus electric fan, painless center ashtray switch panel and misc stuff like wiring, connectors, relays, etc.
I know your running a 10x's more aggressive setup than me but I pretty much stock 302 in the car now, and I can beat the ***** off of it in 100 weather for a long a$$ time and not have to put the high switch on...
88BlueGT is offline
Old 10-22-2008, 01:51 PM
FOUR EYE
FOUR EYE's Avatar
Sounds like it works and that's what matters. I like the idea, thanks again...
FOUR EYE is offline
Old 10-23-2008, 08:20 AM
Project 5.GO!
Project 5.GO!'s Avatar
Some pretty good info here, but I'm going to tell you something a little different. Go with the Fluidyne, and the Taurus fan, but get a Delta Current Control to drive it and skip all the relays and switches and switch panels. It will be a little more expensive, but you will not have to think about it after the install. All the cars on the street don't require you to throw switches to make sure your car is cooling correctly, so why should yours? Go to http://www.dccontrol.com/0820.htm and read about it. It runs the fan only as fast as is required to keep the car at the temperature you want, and does it without you having to think about it. I think the one you need is the FK35. I don't work for them, just a satisfied customer. Just checked under the hood, and mine is the FK35. Good luck, and if you need help with the install, PM me.
Project 5.GO! is offline
Old 10-23-2008, 08:22 AM
Project 5.GO!
Oh yeah, get the Taurus fan from the junkyard. 25 bucks. And if you haven't upgraded your alternator, make sure you do!
Old 10-23-2008, 10:40 AM
86HOGT
86HOGT's Avatar
Which alternator do you use that's higher output that bolts right in place? SN95? Town Car, etc?
86HOGT is offline
Old 02-01-2009, 12:10 AM
Chaoss84GT50
Chaoss84GT50's Avatar
Don't mean to jack the thread but 88blueGT you got measurements on those brackets you mentioned? I may be the only one interested but I dont have access to the tools to make them so I would have to have a friend do it. Sorry for jacking but just wanted to ask... thanks
Oh and I believe it is the SN95 alt that bolts right up, correct me if Im wrong.
Chaoss84GT50 is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
Beerman309
09-19-2015 01:16 AM
Quick Reply: Need some advice for radiator and electric fans
