manual transmission
manual transmission
how hard would it be,once the motor is out of my car, to convert the stock automatic transmission to a manual and how long ould it take.it is a stock 93 lx.any help would be great thanks.and by the way which kind of tranny would be best for this daily driver?<edited><editID>bobby</editID><editDate>37924.5389351852</editDate></edited>
manual transmission
if it was me I would buy a beefed up C-4with a 2500 stall covertor with shift kit..this will make you as fast if not 1-2 tenths quicker with no missed shifts as well as being easier on the drive train. if you do ALOT of highway driving then the old 4 speed automatic is the way with a stall and shift kit with a big trans cooler
manual transmission
you would need , the whole pedel assembly, clutch cable, compete bellhousing assembly, a trans,flywheel, maybe adiffrent driveshaft, if ya want to do this.. find a donor car and take EVERYTHIGN from the manual trans setup
manual transmission
I agree with the C-4 man. Thats whatI did and I love It. Just make shure you use your AOD flex plate if the tork converter will bolt up because u need that 52 oz whate for a roller motor. Its cheeper than buying one, and uont wont have to change starters.</P>
mungodrums
Suspension
02-09-2016 09:05 AM
BeatnikFink
10-01-2015 08:00 PM
