Car dies when idling..sometime
Old 10-30-2003, 09:40 PM
hot88drop50
hot88drop50's Avatar
Default Car dies when idling..sometime
my starter just went out.. after having the new one installed, when i first start the car.. my rpms drop down form 1000 to 500 and my voltage meter to my battery drops down. Then it goes back up to 1000 and runs fine or stalls. Could this be a bad battery or has anyone seen or experianced this before? i appreciate the help!
hot88drop50 is offline
Old 10-30-2003, 09:44 PM
vfast
I ♥ Acer
vfast's Avatar
or a alt. have it check @ auto zone for free
vfast is offline
Old 10-30-2003, 09:53 PM
89muscle
89muscle's Avatar
did he f*ck with the solenoid. check the connection and grounds.
89muscle is offline
Old 10-30-2003, 11:49 PM
92FordGt
92FordGt's Avatar
<FONT face="Times New Roman, Times, serif" color=green size=3>My car does the same thing now. WhenI start it for the first time for the day it runs rough. I was told it is a part on the throttle body. I can't remember what the part is called, butI think it regulates the idle. My mechanic, also a 5.0 owner, explained that this accumulates carbon after a few years. It's like a $40 part from ford. Not a serious problem though. His does it to. Still, check the battery and alternator. </FONT><edited><editID>92FordGt</editID><editDate>37924.9114814815</editDate></edited>
92FordGt is offline
Old 10-31-2003, 03:03 PM
89muscle
89muscle's Avatar
idle air control motor?
89muscle is offline
Old 10-31-2003, 03:11 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
yea what he said. You can remove the IAC and spray the carbon off with brake cleaner. works wonders. dont use carb cleaner as it leaves a residue
mdvaldosta is offline
Old 10-31-2003, 03:34 PM
hot88dro&#112;50
hot88dro&#112;50's Avatar
so have you tryed this thing with th IAC and the brake cleaner yet? Did it work? Its a pain for me since teh idle never used to do that before.. is this something i should just learn deal with?
hot88dro&#112;50 is offline
djbigskrilla
09-20-2022 01:04 AM
MEISTERSNFB
03-31-2020 07:50 AM
3.7L V6 S550 Tech 2015 - 2017
92
08-24-2018 01:44 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Car dies when idling..sometime
