Help with BBK SSI intake
Old 11-03-2008, 02:30 AM
stewstang
stewstang's Avatar
Default Help with BBK SSI intake
I have the intake all installed, I'm pretty sure I have all the hoses installed, but the car won't start. I think it's my timing, it's cranking over but not firing, and I know fuel is being supplied. I was wondering if anyone has any ideas or if someone has pictures of the setup or stock pictures of the engine compartment to see if I have the hoses all connected. Thank you.
stewstang is offline
Old 11-03-2008, 10:49 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you most likely have the distributor incorrectly installed
mjr46 is offline
Old 11-03-2008, 02:20 PM
fuct59
fuct59's Avatar
check to see if your 180 degrees out on your distributer. tdc is left front cylinder up all the way then drop in the distributer. if that doesn't work like i said before try 180 degree difference. i too have a ssi and found out the hard way.
fuct59 is offline
Old 11-03-2008, 05:46 PM
quickvic91
quickvic91's Avatar
same thing happened last week when my bro put his cobra intake on. distributor was turned 180 degrees off.Couldnt fire up so he went back to stock(the intake is mine now We finally pulled the valve cover off to make sure it was btdc and it finally fired up.
quickvic91 is offline
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Help with BBK SSI intake
