Explorer intake with speed den
I want to put an explorer 5.0 intake on my stock 5.0, along with maybe a 65mm TB? would this work with speed density? I haveread that they flow almost as good as the cobra intakes.
<LABEL id=HbSession SessionId="799073019">Explorer intakes are basically the same thing a gt40 is just looks differently with a few small differences, but yea it flows the same exact way and would fit right on no problems</LABEL>
if the T/B is from a explore you have a lil tweak to do on the linkage...they don't in no way flow as well but are a lot better than the stock one...I used a truck lower and a professional products top.big diffence
they dont flow nearly as good as the gt-40. the intake runners are longer and the diameter tubes are smaller. you would have to do some major porting to get the right flow numbers.
musnicki
09-23-2015 07:11 AM
09-08-2015 11:50 AM
