1 5/8 or 1 3/4 headers?
Old 11-09-2008, 05:58 PM
Js04sILVerBullet
Js04sILVerBullet's Avatar
Default 1 5/8 or 1 3/4 headers?
I bought some LT headers awhile back for cheap for my 88GT that are 1 5/8, but my question is should I ditch those for some 1 3/4 LT headers? or would those be overkill for my setup which consist of
347 with
edelbrock performer RPM aluminum heads
trickflow 1.6 roller rockers
X-303 cam
BBK SSI upper/lower intake manifold
BBK 70mm TB
C&L 76MM mass air meter
4.10 rear gears.
thanks for any input
also would 3in. exhaust be overkill as well?
Js04sILVerBullet is offline
Old 11-09-2008, 06:16 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I run 1 5/8's with my 347 and 2 1/2 exhaust with excellent results
mjr46 is offline
Old 11-09-2008, 06:22 PM
SteveSkal
SteveSkal's Avatar
You've got a pretty big set-up, you may benefit from the larger headers, with a sacrifice of some low end power but with those 4.10's you got that shouldn't be an issue, oh yeah and one other thing, you should probably go with a 75mm throttle body, that 70 is prob too smally for your set-up.
SteveSkal is offline
Old 11-09-2008, 06:45 PM
primetime5.0
primetime5.0's Avatar
the tb is fine
primetime5.0 is offline
Old 11-09-2008, 07:59 PM
Js04sILVerBullet
Alright thanks
Old 11-09-2008, 08:10 PM
94StinkinLincoln
94StinkinLincoln's Avatar
the bigger the better.
the 1 3/4's can be hard to get fitted right, but worth the hassle.
94StinkinLincoln is offline
Old 11-09-2008, 09:16 PM
OnyxCobra
OnyxCobra's Avatar
That's definitely not always true.
I think the 1 5/8" headers and 2.5" exhaust will be enough.
OnyxCobra is offline
Old 11-09-2008, 09:20 PM
94StinkinLincoln
a 347 needs to breath in and out, ALOT more so than a 302. now being he has the rpm heads, he wont make as much power as some other head combos.
i switched to the LT's for a reason, i was fighting mine earlier, they hit in different places on different cars.
im going to 3in all the way back for a reason, i have a BRAND NEW magnaflow magnapack 2.5 catback sitting on the floor, but i have decided to get 3in mufflers to go along w/ the midpipe i have...
Old 11-09-2008, 09:21 PM
83gtragtop
83gtragtop's Avatar
Hardly always true, though you will probably see more peak hp and tq with 1 3/4" with your setup but I don't think it would be a worthy upgrade.
83gtragtop is offline
Old 11-09-2008, 09:22 PM
83gtragtop
83gtragtop's Avatar
Usually you don't want 3" exhaust unless your making over 500hp.
Quick Reply: 1 5/8 or 1 3/4 headers?
