feathered oil pan gasket
Old 11-16-2008, 02:14 PM
yaris0128
yaris0128's Avatar
Default feathered oil pan gasket
The oil pan on my 5.0 is feathered out and leaks oil. I took it in for an estimate and I know its already kinda hard to get at but would you really have to take out the engine to change out a $20 gasket? Plus they were saying 15+ hours of labor. Any ideas on this one if anyone has run into this problem? Cant afford no $1500 for a $20 part.
yaris0128 is offline
Old 11-16-2008, 03:04 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
The engine can be jacked all the way up, the pan dropped while still in the car. The gasket snaked in. W/ a lil finesse, it can be done.
PRO50SC is offline
Old 11-16-2008, 06:29 PM
94_SVT
94_SVT's Avatar
i changed the oil pan gasket on my friends 94 gt (practically the same underneath) with jackstands. We already had the timing cover and all that stuff off but i didnt need to jack the engine up or do anything with the k-member although it would make it a lot easier. And yes snakin the gasket into place while you're under it takes some time.
94_SVT is offline
Old 11-16-2008, 07:05 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
like pro5osc stated it can be done in the car that way....it's a little patience trying but none the less it can be done.....I'd probably figure on 4-6 hrs max depending on your capability to do such work
mjr46 is offline
b8checker
10-08-2015 12:55 PM
Dathan
10-05-2015 05:52 AM
UrS4
10-03-2015 06:23 AM
10-01-2015 09:29 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: feathered oil pan gasket
