Underdrive pully's
Old 11-16-2008, 11:10 PM
saleenpride1986
saleenpride1986's Avatar
Default Underdrive pully's
If I've got a speaker system with upgraded alternator, and power steering and smog pumps, if i were to get underdrive pully's would that be hurting my daily driving? By that i mean, will it have worse steering, and to have the lights and sound on at same time would it bog down the power??? Or will that not really occur to that extent with underdrive pully's?
saleenpride1986 is offline
Old 11-16-2008, 11:34 PM
blkstng95
blkstng95's Avatar
i dont think it will have a noticeable effect, i have bbk pulleys on my daily driver ands its all good
blkstng95 is offline
Old 11-17-2008, 01:08 AM
luckythirteen13
luckythirteen13's Avatar
it shouldnt be a problem but id spend the money on something that will get you better gains then pulleys
luckythirteen13 is offline
Old 11-17-2008, 01:41 AM
saleenpride1986
Well, as of so far i have all the engine parts, the next thing would be pully's, suspension, and frame work. But I will be doing the suspension and framework as a large package and combination work period to do it all at once. + the pully's aren't that expensive and mine are still the stock pully's, everything else enginewise isn't stock at all.
Old 11-17-2008, 09:10 AM
MBDiagMan
MBDiagMan's Avatar
I've used underdrive pulleys in several different cars in traffic, heat and all sorts of conditions with no ill effects whatsoever. The only concern I would have would be your sound system. If it's not over about 120 Watts RMS I wouldn't be concerned about it.
MBDiagMan is offline
Old 11-17-2008, 10:32 AM
luckythirteen13
oh ok, suspension is what i had in mind for you but if you have future plans for that then go for the pulleys. if you find out that the alt is struggling once the kit is on, you can always take the UD alt pulley off and just run the crank and water pump and see how the alt does
Old 11-17-2008, 10:47 AM
very_clean_fox
very_clean_fox's Avatar
I got them on my car and i felt a little diffrence. I would get them and they should have no bad effect
very_clean_fox is offline
Old 11-17-2008, 11:38 AM
saleenpride1986
awesome thanks!!
ctgreddy
09-20-2015 08:35 PM
GimpyHSHS
09-18-2015 12:27 PM
GimpyHSHS
08-29-2015 06:30 PM
WDScott
08-17-2015 06:38 AM
skatepony
07-30-2003 10:12 PM
Quick Reply: Underdrive pully's
