Better than the B/E-303, Stg 1 cams.... IMHO. Did you degree it or plan to degree it?... and it's not the cam you have to worry about, it's the combo you need to make "blower compatible".
i have a stout set-up besides a cam ,but now i have the b-31 on its way here. my dad had mentioned he wanted to degree this cam...is it worth it?
Cam degreeing is a` quality control test + a match up of the cam specs to your setup. The "dot-to-dot" installation is a myth on its own. Installing the cam using the "dot-to-dot" position of a timing kit, does not mean the cam is installed to its cam card specs. IOW..... it's not only worth it in any OTS/custom cam installation, but required.
ok cool, my dad actually has a degree wheel, and he mentioned another tool needed that he has. do i need any kind of specail double roller chain set-up?
