5-lug conversion
Old 12-17-2008, 12:08 PM
79pacecarnewb
79pacecarnewb's Avatar
Default 5-lug conversion
what cars and years can I get axles and front hubs off of to fit a 79 fox to convert it to 5-lug, would crown victoria parts fit? would say like spidle hub and disc brakes off the crown vic. fit on the fox, also the crown vic has a really narrow 8.8 rear in it would it be possible to just swap that out the suspension is setup identicle between the two the only thing I think would be different is width but like I said it is really narrow to be begin with.
79pacecarnewb is offline
Old 12-17-2008, 04:20 PM
Timspony
SVT Section Moderator
Timspony's Avatar
You can use '84-86 Front SVO Or '87 Lincoln Mark 7 rotors with '87-93 front Mustang spindles for sure up front / or, convert to 94/95 splindles as well...
I would look for a '87-93 Mustang 8.8" rear and convert to 5 lug with Ranger axle (lefts only) or go with a Moser type axle...
Timspony is offline
Old 02-03-2009, 11:45 AM
Ford Drag Team
Ford Drag Team's Avatar
I have a question about this as well.
I was told that Ranger rotors or LTD rotors will work on the early Fox bodies.
But should I re-use the Mustang wheel bearings?
Will the Ranger or LTD rotors work?
Thanks
-Joe
Ford Drag Team is offline
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
DCole24
09-11-2015 10:50 AM
YoungStangsMan
09-05-2015 07:01 PM
Quick Reply: 5-lug conversion
