question about EGR
Old 12-17-2008, 03:00 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default question about EGR
ive been getting really bored/bummed not workin on my car. so im trying to think of small easy things i could do so i dont have to be outside for a long period of time.
i dont have any emissions laws here, smog pump is gone, all other crap is gone too, only thing thats left is the egr valve. what would happen if i just disconnected the EGR, took the EGR spacer off and closed off the vacuum line? ive heard the computer eventually factors out the code thrown by having it unplugged. is this true? or do i have to buy that damn sensor delete thing to have it idle correctly?
FivePointOhh is offline
Old 12-18-2008, 08:56 AM
FivePointOhh
in limbo
bumpity bump
Old 12-18-2008, 09:09 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ecm will automatically delete egr function and as long as egr pintle is closed completely, it shouldn't affect idle
mjr46 is offline
Old 12-18-2008, 09:10 AM
Joel5.0
Joel5.0's Avatar
EGR operation and idle control are not related (unless the valve is not seating 100%). As soon a an EGR related code is registered by the EEC, it does automatically delete its function w/out causing any idle, A/F or spark advance issues. The "damn sensor delete" only makes sure that the code registered is 33, which will not cause the CEL to turn on. A failure code 34 , 35 or 32, will cause the CEL to turn on, but will not cause any driveability or performance problems.
Joel5.0 is offline
Old 12-18-2008, 09:46 AM
FivePointOhh
in limbo
so if i get rid of the egr spacer, valve and seal the vac line off this = no problems? thanks guys
Old 12-18-2008, 09:56 AM
nseoi
nseoi's Avatar
DELETE IT!!!
and get that little plug for the harness so that the computer knows to ignore it. google RJM injection i think it is
nseoi is offline
Old 12-18-2008, 10:08 AM
FivePointOhh
in limbo
from what is said above...i dont need it. i'd rather not spend money if i dont have to
Old 12-18-2008, 11:30 AM
Joel5.0
Joel5.0's Avatar
Originally Posted by nseoi
DELETE IT!!!
The computer knows to ignore it w/out the plug..... all it needs is an EGR failure code to show, the plug only prevents the CEL from turning on.
Joel5.0 is offline
Old 12-18-2008, 04:11 PM
ponyponer
ponyponer's Avatar
thats pretty much it. it kinda tricks the computer from throwing the code. i have done the delete. it's a pretty good idea.
ponyponer is offline
Old 12-18-2008, 09:11 PM
minnow81469
minnow81469's Avatar
Do you gain anything from the delete? I want to do a smog delete and block off the egr myself
minnow81469 is offline
Quick Reply: question about EGR
