timing cover
Old 12-22-2008, 05:25 PM
symonds86
symonds86's Avatar
Default timing cover
i need to know what timing cover i need for my the the 69 block im putting in my fox, i need a cover with a built in dipstick. thanks for the help
symonds86 is offline
Old 12-23-2008, 08:03 AM
PJC Racing
PJC Racing's Avatar
You would need P/N RTCF-302A
Keep in mind this is for a standard rotation pump (V-belt)
PJC Racing is offline
Old 12-23-2008, 04:58 PM
symonds86
symonds86's Avatar
ok thanks, is there any cover withg a dipstick that i can use a serp belt?
Old 12-23-2008, 06:58 PM
Portmaster
Portmaster's Avatar
Summit Universal Cover. Works on both styles of water pump and has provisions for a front mounted dipstick
Portmaster is offline
Old 12-23-2008, 07:02 PM
symonds86
symonds86's Avatar
thanks, i'll have to get on summit
Old 12-23-2008, 10:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if it's going in a fox you don't use the timing cover with the hole for dip stick as those are for front sump motors and foxes use a rear sump, so you'd need to get a pan with dipstick in it or mod a stock pan for dipstick
mjr46 is offline
Old 12-24-2008, 08:48 PM
symonds86
symonds86's Avatar
well heres the deal, i bought the motor from the guy who built it and it came out of a fox so it has the right pan and sump but he kept the timing cover to put on his new motor, the pan nor block have provisions for a dipstick
Old 12-24-2008, 09:38 PM
mjr46
mjr46's Avatar
what pan is on it?? pic??
mjr46 is offline
Old 12-24-2008, 10:08 PM
symonds86
symonds86's Avatar
nit sure on brand
Old 12-26-2008, 03:54 PM
symonds86
symonds86's Avatar
portmaster do you have a part number for that cover you were revering to?
Quick Reply: timing cover
