dying on 1st start of the morning
The 1st time in the morning I start my stang it dies and the 2nd it always starts fine.I recently replaced the ACT, ECT, cap, rotor, coil, wires, plugs,fuel filter,IAC, and fuel pump.The only codes i get are 34 and 91.I will be replacing the EGR valve and position sensor as well as both 02's.So I think that will take care of the codes but I dont think it has anything to do with the cold start.Am I wrong?I dont know what else it could be.Any advice?
I just cleaned the MAF w/ MAF cleaner.I also just tightened my headers and both 02's are fully seated and I cant find any vac leaks.Just checked timing and its set @ 11*.I dont have the right tool to check the TPS.Wouldnt it through a code if the TPS setting was incorrect?
no, but if you have a crack in your return line or if your fuel pump check valve is damaged it wont build pressure right away. i had the same problem with my car. hook a guage up to it and see what the pressure is on first start mine was around 10-15psi until i tried a few times and then it bumped up to 30psi ish
Here is a simple thing you can do to find out if f/p is bleeding down. Before you make the first start, cycle the key on then off twice making sure the pump is energizing. On the third try start the car. If it starts w/o dieing, something is happening to the f/p as it sits. If it still dies, you'll have to look elsewhere for the cause.
