inner tierod seal?
Old 12-22-2008, 09:19 PM
dzornes95
dzornes95's Avatar
Default inner tierod seal?
leaking pwrsteering fluid around boot...i'm thinkin cracked seal on inner tierod...hard to change?
dzornes95 is offline
Old 12-22-2008, 09:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you need to replace the rack = that is the fix
mjr46 is offline
Old 12-22-2008, 09:25 PM
dzornes95
dzornes95's Avatar
just the tierod wouldnt take care of it?
Old 12-22-2008, 09:31 PM
mjr46
mjr46's Avatar
no the inner tie rod replacement won't stop the leak the tie rod screws on to the arm on the rack that slides past a seal that is not serviced, a reman rack is 80 buck max
mjr46 is offline
Old 12-22-2008, 09:34 PM
dzornes95
dzornes95's Avatar
gotcha!! thanks man
Old 12-22-2008, 09:44 PM
mjr46
mjr46's Avatar
no problem..also figure on an alignment after rack is replaced
mjr46 is offline
Old 12-22-2008, 10:12 PM
HACKGT350
HACKGT350's Avatar
oh yeah def get an alignment after you replace the rack. i have seen people destroy a set of brand new tires in a day because they refused an alignment. they came back the next day complaining we sold them a crap set of tires and they ended up paying for 2 more tires and an alignment.
HACKGT350 is offline
Old 12-22-2008, 11:56 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
mine is leaking too, its getting replaced along with the K member and im going manual steering baby!!!
FivePointOhh is offline
Old 12-23-2008, 09:59 AM
HACKGT350
HACKGT350's Avatar
thats a good idea. my rack started leaking so i just pulled the pump and have been drive with a power rack with no power for 2 years with out a problem lol
Old 12-23-2008, 10:02 AM
FivePointOhh
in limbo
lolz. yea i think with skinny fronts, manual steering wont be bad, especially shedding about 100lbs off the front with the tube k member and no ac or power steering. and i hear the manual rack is lighter too.
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Demodulates
09-18-2015 11:14 AM
Quick Reply: inner tierod seal?
