NoOB needs help!!
*UPDATE!!!* NoOB needs help!!
well just recently my car has been doing this funny thing where while im driving it jerks. no just 1hr ago it went crazy, the rpms kept going up and doing and the car was jerking. It even shut off on me at a light. Any ideas?
HERE'S THE VID
http://www.youtube.com/watch?v=RiyCdYi6OMw
HERE'S THE VID
I would check to make sure the MAF is connection is completely plugged in and seated. You could be having a failing TFI module located on the passenger fender, below the air-box. Take it to Autozone and have it tested for free. Also, check to make sure you are getting fuel. You could have a bad fuel pump. Good luck!
well it happens after idle pretty much. Im going to go ahead and take all the spark plugs out and check the MAF. I just recently replaced the fuel pump, maybe a fuel line came off? and like 4 months ago i checked the distributor cap and had a small crack on where one of the plugs go, not sure if that would do anything.
good luck,
Cracks don't get smaller, They grow. Fix the obvious then go from there. The cap would be the first place I'd go if I knew it had a crack already
