What supporting mods after H/C/I
Old 12-28-2008, 06:31 AM
jerod187
jerod187's Avatar
Default What supporting mods after H/C/I
hey guys i just did a hci swap i put 69 iron heads with 1.9, and 1.6 valves in and theyre ported and flow benched and all that and a holley cam with these specs
dvertised Duration (degrees) 276 280
Duration @ 0.050” (degrees 221 223
Valve Lift (inches) 0.509 0.509
Lobe Separation Angle (degrees) 112
Opens (degrees) 3.5 BTDC 48.5 BBDC
Closes (degrees) 37.5 ABDC -5.5 ATDC
and a gt40 upper and lower intake and it has mac shorty , H pipe and Flowmaster 40s,
and im in the process of putting 4:10s in its a AOD BTW
so i got around 300 to spend heres the things id like to due
- Throttle body
-B&M mega or hammer shifter
-5" tach
-Pillar post
but u guys got any other ideas as far as performance goes and if any 1 has any used stuff locally im interested! thanks
jerod187 is offline
Old 12-28-2008, 07:19 AM
Portmaster
Portmaster's Avatar
If I had 300 to spend on a car with what you have listed. hmmmmmmm? I'd do at least a new throttle body (70mm) and maybe some kind of ignition upgrade. Maybe new high quality, cap, rotor, wires, coil. Or if thats done maybe a good box like a MSD or Mallory 6AL.
Portmaster is offline
Old 12-28-2008, 08:30 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you didn't mention a stall convertor or shift kit for the AOD......those are the two things I'd concentrate on for your recent h/c/i upgrade
mjr46 is offline
Old 12-28-2008, 03:16 PM
white93pony
white93pony's Avatar
what about suspension or brakes???? might wanna look into some poly bushings and subframe connectors... maybe even some stainless steel brake lines and good pads... you can go as fast as you want but if the car cannot handle it or stop it whats the point???
white93pony is offline
Old 12-28-2008, 03:58 PM
jerod187
jerod187's Avatar
ya i would like to do a stall convertor but i don really wanna drop the tranny lol, But i will think about a shift kit, What would you reccomend a transgo stage 2 or something? Ya we just put new pads and Resurfaced rotors on the front and new struts, but i could use some subframes
jerod187 is offline
Old 12-28-2008, 05:14 PM
mjr46
mjr46's Avatar
convertor or nothing IMO.
mjr46 is offline
Old 12-28-2008, 09:19 PM
Jerome99
Jerome99's Avatar
Throttle body but you kinda need a tach too my tach is WAY off at 6200rpm my stock tach reads 5600, that much diff is enough to make things go boom if your up in the rpms
Jerome99 is offline
Old 12-28-2008, 10:17 PM
FORD TOUGH
FORD TOUGH's Avatar
Thats the best idea. Maybe even a deeper finned aluminum pan for the AOD.
FORD TOUGH is offline
Old 12-30-2008, 12:42 AM
jerod187
jerod187's Avatar
what type of stall convertor and how high of a converotr should i get?
jerod187 is offline
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
TimeLord101
10-01-2015 06:40 AM
Quick Reply: What supporting mods after H/C/I
