hoisting engine?
Old 12-29-2008, 03:35 PM
LesteR723
LesteR723's Avatar
Default hoisting engine?
I pulled the 2.3 engine out of my old fox, and it had a hook to attach to my engine hoist, and i didn't care about banging it up cause it was garbage to me. However, i need to hoist up my nice new pretty 5.0 with long tubes without ****ing anything up in order to replace the passenger side header gasket due to an exhaust leak. The long tubes i have stick out so close to the inner fender that i have no room to get the old gasket out of place to put the new one in. How should i go about getting the engine up enough so that i have room to do this? where should i hook up the hoist to? Thanks.
LesteR723 is offline
Old 12-29-2008, 03:47 PM
hillbilly pony
hillbilly pony's Avatar
you cant.........with the engine swing you are gonna hit side to side. you have to take them off and put them in after the engine is seated....BUT you could get lucky...
hillbilly pony is offline
Old 12-29-2008, 07:24 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Just unbolt the header from the block and the midpipe. Afterward you should be able to move it around enough to replace the gasket.
projectresto83 is offline
Old 12-29-2008, 07:40 PM
racin66coupe
racin66coupe's Avatar
yeah, you dont need much room to replace a gasket at all
racin66coupe is offline
Old 12-29-2008, 11:31 PM
MustangMan628
MustangMan628's Avatar
That is the way to go, and if you have true dual exhaust, you can usually get away with just taking a hanger off and moving the header out towards the fender well. That's what I did. I also usually upgrade the header bolts and buy the gaskets with the little hooks on the end, so you can get them in place easier. Just make sure everything is in the right place before cranking any bolts down.
MustangMan628 is offline
Old 12-30-2008, 12:19 AM
LesteR723
LesteR723's Avatar
like i said in my original post, there is NO room with my long tubes, they stick out TO the inner fender well. and the gaskets that came with the car are damn near melted on, i replaced the driver side already and had to scrape and sand to get that bitch off.
Thus, i NEED to get the engine up. Also, i unbolted the header from the midpipe and couldn't wiggle it out through the bottom or the top of the car.
That being said... will someone please let me know how to get the motor up a few inches safely? Thanks
Old 12-30-2008, 01:17 AM
minnow81469
minnow81469's Avatar
some companys offer a plate that hooks up to your mannifold so you could buy one that will hook up to that and use a picker to lift it up
minnow81469 is offline
Old 12-30-2008, 02:37 AM
95vertGT
95vertGT's Avatar
buy a lift...raise the car....=lower the engine.....lol
95vertGT is offline
Old 12-30-2008, 05:19 AM
hillbilly pony
yeah i understood that the engine was already out!!! and you were putting it back in. you should be able to raise it with a plate. un bolt the trans crossmember and engine mounts and up ya go. should be relatively straight forward. My bad
Old 12-30-2008, 07:09 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
take the dang header off...if you set the motor in with the headers on then for crap sake there is room to get the header out, if it went in it'll come out
mjr46 is offline
Quick Reply: hoisting engine?
