A few tech questions
Old 01-02-2009, 08:09 AM
stickit
stickit's Avatar
Default A few tech questions
I have an 89 5.0 that has a 303 cam, MSD distributor/coil, 75mm BBK Throttle body and a cold air intake. Not much else on the motor. Here are the questions:
1) I wanted to install an Explorer intake:
A)Would it benifit me to go to larger injectors and MAF over stock when I install the intake?
B)What would be the gain to eliminate my EGR when I install the Explorer intake?
2) I want to install a 100+ dry shot system of NOS.
A)What else would be needed besides a larger fuel pump?
B)What gains could I expect from the suggested combos above?
stickit is offline
Old 01-02-2009, 08:30 AM
aode08
aode08's Avatar
A no
B but you will have to any way, less carbon that can produce a ping with NOS.
2.
A. you want a wet system,adjustable fuel pressure regulator,bottle heater,
B.125 Solid HP : ) .5-.9 et reduction 1/4 mile
Use 93 Octane, Cold Air Intake 42 Psi Fuel. Stock pump is fine with that shot, but why risk the volume lol, your doing the right thing
aode08 is offline
Old 01-02-2009, 08:43 AM
stickit
stickit's Avatar
So what size injectors are recommended. Can I upgrade the injectors and MAF and run that for a while before I get the NOS system or will it run rich.
Why is a wet system recommended over the dry NOS?
stickit is offline
Old 01-02-2009, 10:30 AM
15austin
15austin's Avatar
I would get a bigger pump, not even an option with n2o. Wet adds fuel with the shot and dry just adds n2o, so it is a safer way to go. I have ran both dry and wet and no problems with either. If you had the bigger pump and your timing set properly the dry will be fine. You have alot of other mods that need to be done like exhaust for one, i would spend the $ on that over the n2o.
Save up and get a better intake.
15austin is offline
Old 01-02-2009, 11:17 AM
stickit
stickit's Avatar
well I do have other mods I just didnt post. I have long tube headers, H pipe w/o cats to flowmasters with dumps. Also have pullies, aluminum drivshaft, solid motormounts, electric fan and smog pump nixed. Im sure i missed something. Oh gears too...
stickit is offline
Old 01-05-2009, 01:41 PM
stickit
stickit's Avatar
ok so this post to the wayside. I was hoping for more detailed info. Hoping to get more. Any other decent feedback along with the other info I recieved?
stickit is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: A few tech questions
