no power above 3000 rpm
Old 01-04-2009, 06:22 PM
edsvt750
edsvt750's Avatar
Default no power above 3000 rpm
I got this car wrecked. I just got it back together. It has new wires, plugs, dist., dist. cap & rotor. I removed the smog pump & vapor canister,plugged the vac. line. It revs fine out of gear & in 1st. 2nd & up under load-no power above 3000rpm. It's like it's hitting a rev limiter. Any help would be appreciated.
edsvt750 is offline
Old 01-04-2009, 06:51 PM
91lx50udlose
91lx50udlose's Avatar
what is the timing set at?
kind of sounds like it doesn't have enough timing to me
91lx50udlose is offline
Old 01-05-2009, 10:43 AM
edsvt750
edsvt750's Avatar
i'm kinda new to this. i don't know what the timing is set at. How do check that?
edsvt750 is offline
Old 01-05-2009, 02:35 PM
MustangEnthusiast7
MustangEnthusiast7's Avatar
Theres several ways do you still have the manual??
MustangEnthusiast7 is offline
Old 01-06-2009, 09:24 AM
edsvt750
edsvt750's Avatar
I do not have any instruction manuals of any kind. FYI, my first drive in this car it ran great pulled hard at all rpm's. The 2nd time is when this problem occured. I checked the plugs and they look clean.
edsvt750 is offline
Old 01-06-2009, 10:27 AM
calfroper_06
calfroper_06's Avatar
check you grounds
calfroper_06 is offline
Old 01-06-2009, 10:59 AM
ttocs
ttocs's Avatar
shift at 2999, PROBLEM SOLVED!
ttocs is offline
Old 01-06-2009, 04:24 PM
HACKGT350
HACKGT350's Avatar
check for a vacuum leak just to make sure you didnt miss anything. to check your timing you will need a timing light. you attach the wire loop around the cylinder 1 wire, hook up the positive and negative wires to the battery, pull the spout connector (two wires off the dizzy that go no where with a little connector on the end), fire the car up and point the light at the harmonic balancer pull the trigger and you will see numbers every time the light blinks which will be very fast.
HACKGT350 is offline
Old 01-10-2009, 07:38 PM
edsvt750
edsvt750's Avatar
To:calfroper-i;ll check the groungds. To:ttocs-good idea...not. Appreciate the humor though. To: HACHGT350-I'll check the vacum lines again. Thanks for the info. on checking the timing. I misunderstood the question, I know how to check timing (brain fart). I haven't worked on the car in several days. Thanks to all for the help/humor. I'll let you know my progress(if any)
edsvt750 is offline
uberstang1
12-07-2017 07:10 AM
uberstang1
09-20-2015 06:42 PM
2015Ecoboost
09-17-2015 01:48 PM
Daddys Girls GTs
09-14-2015 08:46 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: no power above 3000 rpm
