turn signal problem! need some help
Old 01-10-2009, 01:32 AM
1990fox5.0
1990fox5.0's Avatar
Exclamation turn signal problem! need some help
when i turn the turn signal lever to the left it works fine and flashes but when i push it to the right it doesnt flash it just stays soild, i thought it was a fuse so i replaced the circle fuse under the driverside dash but did help does any one have a idea thaxz.
1990fox5.0 is offline
Old 01-10-2009, 01:38 AM
FORD TOUGH
FORD TOUGH's Avatar
Did you replace the flasher?
FORD TOUGH is offline
Old 01-10-2009, 01:41 AM
1990fox5.0
1990fox5.0's Avatar
is that the circle fuse under the dash, cause i replaced that i dont kno if there is mybe two for each side, and i replaced the wrong side
Old 01-10-2009, 01:42 AM
FORD TOUGH
FORD TOUGH's Avatar
The thing labeled hazard flasher?http://www.veryuseful.com/mustang/te...angFuseBox.gif
Old 01-10-2009, 06:33 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Originally Posted by FORD TOUGH
If that's the one you replaced, it's the wrong one. That's for the hazards. There is another one for the signals behind the glove box door area.
PRO50SC is offline
Old 01-10-2009, 07:56 AM
Timspony
SVT Section Moderator
Timspony's Avatar
I recently had to replace to turn signal lever for my daughther's '91 GT...took about 10 mins. & $150....
Are the lights coming on at all OR is it dead?
Timspony is offline
Old 01-10-2009, 11:15 AM
FORD TOUGH
FORD TOUGH's Avatar
Thats where I was going with that but the guy never responded last night so I went to bed.
Old 01-10-2009, 12:02 PM
P.S.I.cho
P.S.I.cho's Avatar
it could possibly be the turn switch or lever as stated above pretty simple fix, just pull of plastic covers around the steering wheel and its right there, while your in there you could test it, turn left check with a test light does it light up the test light? turn right same proceedure? if no replace switch.
P.S.I.cho is offline
Old 01-10-2009, 08:10 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
I think I would replace the flasher first. It's easier and cheaper and that's generally the problem.
PRO50SC is offline
Old 01-10-2009, 10:17 PM
1990fox5.0
1990fox5.0's Avatar
sorry ford tough fell asleep, ill try the other flasher behind the glove box
Quick Reply: turn signal problem! need some help
