do i need these
Old 01-10-2009, 02:40 PM
1988TTOP
1988TTOP's Avatar
Default do i need these
do i need the thermactor air diveter and the thermactor air bypass since i am not running any the egr or the smog pump and what else can i get rid of i am in the process of hide all the wire and smothin out the engine bay and gettin rid of the thing i do not need
1988TTOP is offline
Old 01-10-2009, 03:15 PM
Modular_Madness96
Modular_Madness96's Avatar
Do you mean the thermactor tubes that go between the heads?If so just use a couple of NPT plugs.
Modular_Madness96 is offline
Old 01-10-2009, 03:18 PM
1988TTOP
1988TTOP's Avatar
they have vac line that run to the smog pump
1988TTOP is offline
Old 01-10-2009, 03:59 PM
1988TTOP
1988TTOP's Avatar
1988TTOP is offline
Old 01-10-2009, 04:00 PM
1988TTOP
1988TTOP's Avatar
1988TTOP is offline
Old 01-10-2009, 04:05 PM
1988TTOP
1988TTOP's Avatar
these are r the pass side and do i need i belive it is for the cruse control on the drivers side under the fender
1988TTOP is offline
Old 01-10-2009, 07:05 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no you don't need emissions stuff to retain drivibility
mjr46 is offline
Old 01-10-2009, 07:11 PM
1988TTOP
1988TTOP's Avatar
so i dont need the thing in the pic
1988TTOP is offline
Old 01-10-2009, 07:15 PM
mjr46
mjr46's Avatar
that is a vaccum resevoir for I believe the HVAC.......so you may need it, trace the vac line to source where it originates from
mjr46 is offline
Old 01-10-2009, 07:23 PM
FORD TOUGH
FORD TOUGH's Avatar
How are you going to get it through inspection?
FORD TOUGH is offline
