Intermittent backfire/hesistation
The car has developed some hesitation and sometimes a backfire at 5k rpms plus. This all started yesterday when I was beating on the car and it backfired really loud. The car isnt showing any codes, timing is good. Any pointers? tips?
I've had the same problem. Only when the car warms up and I'm going down the highway at 70 mph it will stutter or stall, when it catches it will backfire too. Others suggested TFI module, maybe the coil's going out. Definately an ignition issue. Backfire says it's getting fuel.
My 91 fox body was doing the same thing and still is. I had a thread up about it earlier, here is the link. https://mustangforums.com/forum/5-0-...5-000-rpm.html hope it might help you out a bit.
Not sure if this link will help, but hopefully at least point you in the right direction in testing the pick up.
http://www.therangerstation.com/tech...iagnostic.html
