headlights going out...
Old 01-11-2009, 08:27 PM
GT350son
GT350son's Avatar
Default headlights going out...
just a few minutes ago when I was driving in the dark my headlights started to turn off an on.... I was almost home and all of a sudden my headlights turned off on me for no reason. Then not a second later it turns back on. It did this about 10 times when i was about 1/8 mile from my drive. So I don't know if it would have stopped. Anyone have an idea whats causing this?
GT350son is offline
Old 01-11-2009, 08:47 PM
Riceinator
Riceinator's Avatar
Were your foglights on as well?
Riceinator is offline
Old 01-11-2009, 09:18 PM
GT350son
GT350son's Avatar
fog lights were turned off
GT350son is offline
Old 01-11-2009, 09:31 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
could have a bad connection or high resistance at a connection, I'd grab a wiring diagram and trace circuit and look at all connection points for overheated connections/ melted portions in the connector
mjr46 is offline
Old 01-11-2009, 11:23 PM
FORD TOUGH
FORD TOUGH's Avatar
Do you have the stock head lights?
FORD TOUGH is offline
Old 01-12-2009, 02:41 AM
GT350son
GT350son's Avatar
They are not after market ones.
GT350son is offline
Old 01-12-2009, 09:24 AM
ttocs
ttocs's Avatar
we can only help you if you give us the details. What kind of lights are they? HID, projector? Was your switch warm?
ttocs is offline
Old 01-12-2009, 09:34 AM
FORD TOUGH
FORD TOUGH's Avatar
Good I have seen a neon with silverstars and it burnt up the whole dash harness. You should check your wiring or maybe you have a bad switch.
Old 01-12-2009, 04:33 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
He drives a gt350, hense 4 eye . Was it the doing it in both the dims and the brights? Did the dash lights go with it or just the headlights?? Is your car charging right??
projectresto83 is offline
Old 01-12-2009, 05:16 PM
GT350son
GT350son's Avatar
Well it wasn't happening long enough for me to get enough details. I had to lights on bright and then only the headlights went on and off. When I switched it to dim it stopped for a few seconds then started again. And the car seems to be charging just fine. Also the amp meter shows it straight up right between - and +
It doesn't do this every time I drive it at night. Last time it happened was a couple weeks before christmas
GT350son is offline
Quick Reply: headlights going out...
