Headlight switch ????
Old 01-13-2009, 04:06 AM
1SICK86COUPE
1SICK86COUPE's Avatar
Question Headlight switch ????
I have an 86 gt and i would like to know if there is anybody that has the diagram of the headlight switch . I would like to replace the switch for toggle switch style i would like to have a switch for the 1/4 lights and the brake lights and the headlights.I am having switch problems and i have replaced the switch three times allready for the same thing , the headlights turn on and off when the switch warms up.i do not want to keep buying switches so if anybody can help me it will be helpfull . thanks for your help
1SICK86COUPE is offline
Old 01-13-2009, 07:02 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
replacing and rewiring what you want to do into a cluster "f" will not solve your problem, you have excessive current draw due to a faulty connection or high resistance in the circuit somewhere, causing high current draw and inturn overloading the switch, examine all connections, harness connectors and consumers in the system.
mjr46 is offline
Old 01-13-2009, 09:28 AM
rhstang2
rhstang2's Avatar
it aslo may be your turn signal switch in the column i had simular problem and turned out to be the turn signal due to high ristance in the wiring that ford used to small of a gauge wire and after years of use when it gets hot and shorts out and turns lights in and off
rhstang2 is offline
Old 01-13-2009, 10:04 AM
FORD TOUGH
FORD TOUGH's Avatar
Do you have stock headlights bulbs?
FORD TOUGH is offline
Old 01-19-2009, 12:51 AM
1SICK86COUPE
No i donot have stock bulbs i upgraded to aftermarket to the H 4 headlight swap they are clear with the light blue bulb but it still dose it with these lights.can anybody help me out i need to fix this problem now that the car is sitting in my driveway because im doing some body work.help please its getting anoying,
lincolnshibuya
07-05-2020 03:05 AM
PaulH2
20
01-31-2016 09:48 AM
StalkerGT
11-28-2015 03:09 PM
guitarman376
09-30-2015 05:54 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: Headlight switch ????
