how to 2 step??
Here's a list. I have a ton of pics of the rebuild if you want to check them out. Just let me know.
FRANKENSTANG
No times or Dyno numbers yet.
Engine: 347 c.i. Stroker
LOWER:
Summit 302 block machined for 347
Eagle Forged crank
Eagle Forged rods
Keith Black flat top .040 valve relief pistons
Trick Flow cam dur. 275/279 Lift .499/.510
Pete Jackson Gear drive (noisy)
Milodon high flow oil pump
Milodon 8qt oil pan
UPPER:
Trick Flow Twisted Wedge Track Heat heads (ported/polished)
2.02/1.60 Valves
Trick Flow 1.6 RR
ARP Studs
Trick Flow Upper/Lower intake (ported/polished)
FoMoCo 24lb injs.
BBK 75mm TB
Granitelli 75mm MAF
BBK fuel press. reg.
BBK CAI w/K&N Filter
Drivetrain:
1965 C4 trans (hardened clutches, 33 spline input shaft)
TCI flexplate
TCI 3500 stall
Ignition:
MSD 6AL
MSD 2 step module (stutter box)
Taylor 10mm wires
Exterior:
2000 Cobra RR Cervani hood
Saleen Wing
Weld Draglites (Front) 3.5 Euro Skinnies
Weld Draglites (Rear) w/ 26x10.5 15 M/T E/T streets
Suspension:
UPR Tubular K-Member
UPR Tubular A-Arms
UPR Bump Steer kit
UPR coil over kit
MM Caster/Camber plates (4 ways)
Sub Frame connectors
8.8 rear W/C-Clip eliminators
33 spline Moser axles
Spool w/3.55 gears
Moser housing cover
hey frankenstang! arnt those 24# injectors a little small for a 347?
ANd you could always look into a PMS tuner, which also has a built in 2 step along with the ability to tune your car... just a thought, www.andersonmotosport.com sells them
oops wrong web page, its www.andersonfordmotorsport.com
Well, the problem is, I bought the entire upper part of the engine to sit on a stock 302 bottom. I had to rebuild the engine thanks to a spider journal bolt being a tiny bit too long and bending one of my cam bearings. I thought, I might as well stroke it since I have to rebuild it anyway. I also couldn't send the parts back because I had already installed and used them. Not to mention I had already ported and polished the heads and intake.
"frankenstang" that is a SICK car.
you should get some videos going of it!
im planing on a 347 some day, but im trying to step away from putting all the money into my car, and focus on getting a house.
id love to see videos, dyno, and some track times for that thing when you can.
