EFI or Carb
EFI or Carb
i have been debating this since started building the car, as ya know im building a 347 with 225 afr heads the block came with a CI cam that was built for a EFI car. and i am weighing my options here. i know carb would be cheaper and easier to tune, plus there are no tuners around here. but i would have to get a new cam, intake, and dizzy. if i went EFI i wouldn't need a new dizzy, i already have a efi vic jr intake and a cam. but injectors, maf, and tb cost a ton as you know, plus i have to haul the car 100 miles to get it tuned. what are your guys opinions here. thanks
I'm curious about this, but I have heard that you can run your stock dizzy.....as long as you leave your computer in the car???? have no idea, but all I've ever heard you need to run carb is a 4bl intake, carb, and fuel pressure regulator and/or low psi fuel pump?
I will defer to someone that has more knowlege on this
My vote is for carb tho
these are the cam specs there isn't any reason i couldn't run it if i went carb are there? as long as the carb is the correct size then it should work correct?
intake:
AT .006: 276.01
AT .020: 252.34
At .050: 224.32
LOBE AREA AT .050: 28.15 In*Deg
AT .200: 148.98
LOBE LIFT: .37749"
LASH HOT: HYD HOT
ROCKERS RATIO: 1.6
GROSS LIFT: .604"
LOBE CENTERLINE: 110.33ATDC
OPEN AT .050: 1.83 BTDC
CLOSE AT .50: 42.49 ABDC
LIFT AT TDC: .0499" @ 110.33 ATDC Intake Center
Exhaust:
AT .006: 307.22
AT .020: 272.58
At .050: 240.69
LOBE AREA AT .050: 28.76 In*Deg
AT .200: 154.41
LOBE LIFT: .35999"
LASH HOT: HYD HOT
ROCKERS RATIO: 1.6
GROSS LIFT: .576"
LOBE CENTERLINE: 115.35BTDC
OPEN AT .050: 55.69 BBDC
CLOSE AT .50: 5.00 ABDC
LIFT AT TDC: .0682" @ 115.35 BTDC Entake Center
Notes to James Sleicher:
Cranking Compression 185 PSI
Idle Vacuum 13.5"
Idle RPM 800 RPM to 900 RPM
Peak Torque 4600 RPM
Peak Horsepower 6100 RPM
Torque Converter Stick Shift
Sharting Shift Point 6800 RPM
Starting Cross RPM 7000 RPM to 7200 RPM
REDLINE 7400 RPM
intake:
AT .006: 276.01
AT .020: 252.34
At .050: 224.32
AT .200: 148.98
LOBE LIFT: .37749"
LASH HOT: HYD HOT
ROCKERS RATIO: 1.6
GROSS LIFT: .604"
Exhaust:
AT .006: 307.22
AT .020: 272.58
At .050: 240.69
AT .200: 154.41
LOBE LIFT: .35999"
LASH HOT: HYD HOT
ROCKERS RATIO: 1.6
GROSS LIFT: .576"
Idle Vacuum 13.5"
REDLINE 7400 RPM
