Trick Flow or Edelbrock?
Old 01-21-2009, 06:28 PM
  #21
94StinkinLincoln
94StinkinLincoln's Avatar
EFI Spyder Elbo ftw
94StinkinLincoln is offline
Old 01-21-2009, 09:02 PM
  #22
barney50
barney50's Avatar
So the spider is the way to go? Where is the best place to get the spider? What does it cost? I have heard that the ports on the Holley don't match well with all heads.
barney50 is offline
Old 01-21-2009, 09:28 PM
  #23
94StinkinLincoln
the spider is the efi "version" on the eddy Victor Jr. (its a carb intake).
the Super Victor can be done the same way...
imagine a Daily Driven 306 with a Super Victor sitting on top, Naturally Aspirated.
he is in love with the intake, no complaints from him yet, and the cam was ground for use of the ported Holly II intake, that is now for sale .
here is my efi vic jr:
Old 01-21-2009, 09:42 PM
  #24
symonds86
symonds86's Avatar
i have one for sale in the for sale section
symonds86 is offline
Old 01-21-2009, 10:13 PM
  #25
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
just run the rpm II and be done with it
mjr46 is offline
Old 01-22-2009, 07:20 PM
  #26
barney50
barney50's Avatar
Ok. Should I go with the Holley II or the Edelbrock RPM II then? I read up on the spyder and it's good for the 4000 RPM and up. I want power at a little lower RPM too. I want low end torque too. I like the way the RPM II has a broader rpm range 1500-6500 and the Holley shows 2000-6500.
barney50 is offline
Old 01-22-2009, 07:29 PM
  #27
ViperblueGT
ViperblueGT's Avatar
definitely need to go with the edelbrock i have ran them on two of my mustangs and work amazing right where you need them
ViperblueGT is offline
Old 01-22-2009, 07:35 PM
  #28
94StinkinLincoln
how much air does a 302, a 331, and a 347 need at 6500rpms?
ask yourself this: how much time will i spend below 4,000rpms when i am drag racing; i have a (i am assuming a stock t5, since a tko was not listed) T5 with a 2.95ish first gear ratio, 3.73's and a blower. the minimum launch rpm should be at least 3,000rpms.
and did you not read the pm i sent you?
Old 01-22-2009, 07:36 PM
  #29
mjr46
mjr46's Avatar
either one will work, but it's not so much the intake that'll dictate the rpm power band, that is just where the intake best supports power, what'll be key in developing the power band you want is the cam and a properly set up valvetrain as well as other things
mjr46 is offline
10-26-2015 05:01 PM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
tramphardrocker
09-13-2015 08:56 PM
09-10-2015 08:39 PM
Gabe_mlcc
09-07-2015 11:56 PM
Quick Reply: Trick Flow or Edelbrock?
