fng question
Old 01-20-2009, 01:16 PM
hdpearson13
hdpearson13's Avatar
Default fng question
hello this is a nice place i got a suspension question? this is first car project. my 94 gt steers all over the place? no idea what it is any ideas i should look at or has any one had similiar problem. thanks alot.
hdpearson13 is offline
Old 01-20-2009, 04:16 PM
wrenchturner75
wrenchturner75's Avatar
well if the tires are properly inflated and wheels are tight, check for any loose suspension parts by jacking up the front end and place your hands one at 12 o clock and the other at 6 o clock and try to move the tire in and out, if no play place hands at 3 o clock and 9 o clock and try to move tire in and out, repeat on other side of car, if you found no play thats good, if you did then you have a bad balljoint or tie rod end. replace any worn parts and get the front end aligned, if you have excessive positive or negative toe it can cause the car to drive very erratic. hope this helps.
wrenchturner75 is offline
Old 01-20-2009, 05:33 PM
hdpearson13
12 and 6 there loose. is toe the same as camered? changed outer front tie rod but didnt have time too do other side and inner front driver side moves too. I ran out of time at the base auto shop/
thanks for any help? whould it be the steering box if one inner tie rod seems tight and the other seems loose?
Old 01-21-2009, 09:23 PM
hdpearson13
just got done changing inner tie rod in driveway. it seemed to take away the 3 to 9 movement that I had o drivers front. wheel bearings seem good now I think I just need a bunch of bushings and some wedge in the back. does anyone use wedges on there stang?
Old 01-22-2009, 03:07 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
ummm no, this isn't nascar
projectresto83 is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: fng question
