Cam Thrust Plate Breakage
So anyone know how you can break the thrust plate? I pulled my oil pan off to check the bearings while I have my motor out and I find a small bolt and an ear to something. Well I search around and think about it and see everything on my oil pump is intact so I'm thinking to myself there is only one other thing that is that small that can fall in here. The only thing that got me is that all the ones I have seen use a allen head (torx maybe I don't remember exactly) bolt to hold it down. Well I pull my timing cover off and I see the little plate just rocking back and forth behind the cam gear.
Good thing I decided to tear into the motor a little huh .
What problems could have arised from the thrust plate not being held down? More wear on the cam than normal probably?
No I didn't install this, I havn't messed with anything past the timing chain on this motor before now. Just the top end of it.
The only way I know you could break a thrust plate would be for the bolts to be loose. Without a thrust plate it will allow the cam to walk. It will probably rub the block and timing chain cover. You will probably want to get a new timing chain too. Yes there would be more wear on the cam.
One of the bolts probably backed out and was knocked off my the timing chain and cam gear. It probably didn't hurt anything, unless you noticed a problem with it before you tore it down. Any problems with oil pressure? You could always pull the cam and inspect the bearings. Shouldn't take but a few minutes.
Timing chain was tight,(still old and will be replaced), I had no problems before tearing it down. It looks like the one bolt I found backed out and tooth a couple of threads with it. Do some motors use hex head bolts on the plate? I just have to replace the plate right now. I may pull the cam but IDK if I want to yet. I am gonna replace it after Iraq so I might as well.
