STEEDA #19 CAM IN MUSTANG WITH S/D ?
Old 01-28-2009, 10:36 AM
87 T TOP GT302
87 T TOP GT302's Avatar
Default STEEDA #19 CAM IN MUSTANG WITH S/D ?
Is anyone running or has anyone used this cam steeda #19,in a mustang that is still speed density??If so how does or did it do as well as idle quality and power ?What about this cam with1.7 rr.?Do you have to fly cut the pistons since duration is 226/220?
87 T TOP GT302 is offline
Old 01-28-2009, 10:52 AM
steel1
steel1's Avatar
I run a Steeda #18 w/1.7rr in my 93GT. Bottom end is stock, had no ptv issues, but should be checked on every build. I have been really happy with the performance. The Steeda #19 has the same specs as the#18 except for a wider lobe seperation (#18 112*, #19 115*). 19 gives better vacuum at idle, required by 94-95 mustang. Don't know how either would react in an sd car.
steel1 is offline
Old 01-28-2009, 12:02 PM
crueheadstang87
crueheadstang87's Avatar
if im not mistaken sd cars require a cam with 115* of lobe seperation. IF you go to the sd forum in the 5.0 section one of the guys in there should be able to help you find a cam that will work with sd.
crueheadstang87 is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
Urambo Tauro
12-17-2016 03:30 PM
robjh22
08-17-2015 07:35 AM
ding56
08-14-2015 02:40 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: STEEDA #19 CAM IN MUSTANG WITH S/D ?
