How to replace washer fluid switch?
How do you pop off the washer fluid switch thats at the back of the resivoir? i popped off the little clip and tried to twist and pull the switch and nothing happens. i would rather ask here first before i break the mating area on the resivoir. thanks
This is from the 89 Ford Shop Manual.
For Testing the pump the Manual says;
Attach leads of the volt-amp tester, the current draw should not exceed four amps, or indicate less two amps, while washer pump motor is pumping fluid.
thanks. i ended up figuring it out. i just gripped it with pliers and pulled. the only thing i didn't do is use dry lube on the rubber fitting. oh well, i hope it doesn't leak. thanks Almost
bond007
08-26-2015 11:36 PM
