Visually check for bad syncro's
Can you visually tell if syncros are going bad or need to be replaced? The 93 I am getting saturday has a t5 sitting in it and the guy selling it said the previous owner told him that it needed new ones. I thought about just throwing it in the car and seeing how bad it does grind but I figured I would pop the top off and see what damamge there is. Yes it is a cheap rebuild for the most part but don't want to if it doesn't have to be done yet. trying to find other ways to spend my money after iraq
in all honesty if you have it that far apart to see the syncros rebuild it. hell in about an hour you can have it redone with it that far apart already. not hard at all to do. id like having the piece of mind knowing its ok as im stuffing it in. yikes that sounded dirty!
if they are real bad yea youll be able to tell, sometimes they will grind like when grabbing 2nd but you take it apart and they look fine, its happened to me. if you heard that it needs syncros then it would be enough for me to replace em. if they are real bad theyll have gouges in the brass blocker rings, the edges of the teeth in the shape of a triangle will look beat up, if they are that bad pay close attention to the gears as well. normally the syncros take the brunt of the beating but when guys are ramming them into gear with bad syncros thats when the gears get screwed up. while your at it spin the input shaft and listen for any and i mean any bearing noise, if you hear it spinning it by hand rest assured its gonna howl like a banshee when you drive it.
Thanks mjr, thats the answer I was looking for. Apparently, wrench boy up there didn't read the whole post. But thanks for the input wrench.
I get to pick up the car tomorrow morning so I will try to have some pics up and maybe some info about it. I might be able to pull the trans apart to inspect this weekend but I don't know. I deploy thursday so I have alot to do between now and then. I am hoping the thing has a set of gears and lower control arms already. That would be a great bonus.
that gets pricey
thats only on 5th gear
new ones are sharp, if they are getting rounded off they are getting bad
blocker rings take the abuse and if they are worn the syncros then begin to get damaged.
