HELP HELP HELP! new OIL PUMP installed
Old 01-29-2009, 08:40 PM
92FOX
92FOX's Avatar
Default HELP HELP HELP! new OIL PUMP installed
Car cranks but will not turn over after new pump , and drive? Y
Please help ! NEW MAF AND IAC ALSO
92FOX is offline
Old 01-29-2009, 08:42 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
did you remove the distributor at all??? do you have spark or fuel = have you tested for either??
mjr46 is offline
Old 01-29-2009, 08:46 PM
92FOX
92FOX's Avatar
No, How do i test spark And Fuel?
92FOX is offline
Old 01-29-2009, 08:54 PM
1988TTOP
1988TTOP's Avatar
do u have a spark tester or a fuel pressure tester
1988TTOP is offline
Old 01-29-2009, 08:59 PM
92FOX
92FOX's Avatar
i have one of those elecronic tester in a kit? , Be more specific i never tested spark or fuel dont even know what to do ?
92FOX is offline
Old 01-29-2009, 09:00 PM
mjr46
mjr46's Avatar
grab a can of spray start, spray it in the intake , if it fires up and dies= fuel issue....if not grab a used spark plug pull a wire insert test plug and have someone crank it while you ground electrode and look for big blue spark arcing
mjr46 is offline
Old 01-29-2009, 09:03 PM
1988TTOP
1988TTOP's Avatar
the way i test for it is i grab a old plug and hook it up to a wire and ground it out and turn over the car and see if u get spark
1988TTOP is offline
Old 01-29-2009, 09:19 PM
92FOX
92FOX's Avatar
lol, call me dumb but i dont understand what the test plug purpose is?
92FOX is offline
Old 01-29-2009, 09:20 PM
1988TTOP
1988TTOP's Avatar
u will see the spark in the gap of the plug
1988TTOP is offline
Old 01-29-2009, 09:33 PM
mjr46
mjr46's Avatar
as stated to see the spark
mjr46 is offline
Quick Reply: HELP HELP HELP! new OIL PUMP installed
