Ignition stuck in lock
Old 02-13-2009, 03:04 PM
  #21
Sparky73
Sparky73's Avatar
Originally Posted by primetime5.0
Ill see if I can find a pic of where the pin is.. I know its on the back side towards the seat
Thanks man. That would be great! What are my chances of screwing something up? I was trying to find info on drilling it out, and read a bunch of stuff (in a different type of car) that said you had to drill like 1.5" to get the pin out, and 1.25" into the actual ignition.. and if you went to far, a whole new steering column would be needed.
I also have this thread posted as well..
https://mustangforums.com/forum/5-0-...-involved.html
FORD TOUGH says the ignition has to be in the 'on' position to get the cylinder out. I understand drilling it out would resolve that problem since mine WONT go into the 'on' position, but could I do as he says and break it loose with a screw driver, and then just remove the cylinder without drilling anything? Sad to say.. but I don't own a cordless drill and there is no power available to me.
Sparky73 is offline
Old 02-14-2009, 12:47 AM
  #22
primetime5.0
primetime5.0's Avatar
I dont see it being possible to break the pin out with a screw driver
primetime5.0 is offline
Old 02-15-2009, 08:22 PM
  #23
Sparky73
Sparky73's Avatar
Anyone ever find a picture of that pin and/or instructions on exactly how to do it?
Sparky73 is offline
Old 02-15-2009, 09:13 PM
  #24
primetime5.0
your going to need to pull the plastic off around the column, its easy to spot
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:58 PM
Quick Reply: Ignition stuck in lock
