New Starter
Old 02-01-2009, 01:57 PM
saleenpride1986
saleenpride1986's Avatar
Default New Starter
I'm trying to find a good deal on a starter, but there's so many different ones out there. I have a stock starter and after i drive around for a while, turn the car off go to other places and all that again, it starts to have starting issues. Should i go with a higher torque rated one that is the same OE specifications or get a mini with high torque rating etc etc.
Also, what brand is good and also, even though the manufacturers of the mini starters say it fits like OE starters, is that actually true? They look quite a bit different when in comparison to the stock 5.0 starter.
saleenpride1986 is offline
Old 02-01-2009, 02:22 PM
wrenchturner75
wrenchturner75's Avatar
i was having the same problem after i installed long tubes, i run the powermaster reduction starter and it solved all my problems, spins over faster, and even when i let it sit in the summer after a min or two it spins it right over. although a little pricy at over 200 bucks, but it fixed it so im happy, and yea it slid right in and was smaller than my factory 50 pound pos starter!
wrenchturner75 is offline
Old 02-01-2009, 06:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
in 1992 a gear reduction starter was now offered, I upgraded to such on my 85 and all that is required is a little rewire as the selonoid is mounted on top of the starter in 92...I had the same issue with heat soak as my headers wrap around the starter, the gear reducion stock one cured issue
mjr46 is offline
Old 02-01-2009, 06:11 PM
FORD TOUGH
FORD TOUGH's Avatar
Just buy a stock replacement one from napa or carquest. You could upgrade to a gear reduction starter off of a 94-95 gt.
FORD TOUGH is offline
Old 02-01-2009, 06:21 PM
mjr46
mjr46's Avatar
92-95 to be correct
mjr46 is offline
Old 02-01-2009, 11:17 PM
saleenpride1986
awesome, thanks for the help guys!
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
daytooday
09-01-2015 09:33 AM
Quick Reply: New Starter
