weight reduction
#21
5 speed car?? When i was manual I had ET Streets and I would launch at 5k and let em spin i would have the tire pressure around 12,13 pounds...my 60 ft's were 1.68's, it was awesome...I wouldhave never though that spinning the tires would be good....but it kicked a$$....dunno what your working with though.
#23
So far what I did for weight reduction
A/C delete
Power Steering delete (flaming river set up)
Aluminum Radiator
Alt only set-up
Aluminum heads
Aluminum Intake
No sway bars
Tubular K Member
Tubular Control arms
Front Coil overs
Power brake delete
Optima battery in trunk
manual windows (factory)
No electric locks (factory)
Aluminum driveshaft
Rear suspension swap
Lighter wheels/tires
50% weight reduction in exhaust
Probably 20 lbs of other usless junk under the hood
No spare/jack
Things that add some weight.
9 inch Currie rearend +24 pounds
Electirc fuel pump and lines
Battery cables (rear mount)
Subframe connectors
A/C delete
Aluminum Radiator
Alt only set-up
Aluminum heads
Aluminum Intake
No sway bars
Tubular K Member
Front Coil overs
Power brake delete
Aluminum driveshaft
No spare/jack
Subframe connectors
09-08-2015 11:50 AM
1993, 460, 91, engine, ford, fully, gt, maximum, motorsports, mustang, oil, reduction, reductions, synthethic, weight
