proper way to break in engine/cam (roller cam)(new engine)
#22
^^^^drive it normally like you would, once all is set up and no odd noises are heard, I drove mine for about 5 miles easy to listen for odd noises then I accidentilly pushed the accelerator hard into the floor boards!!lol ......if it's gonna come apart , it'll do it right away and if it does it won't matter if you drove it like you stole it or babbied it for 3000 miles, cause if it flies apart, then tolerances or something was not set up right
#23
#24
my engine is a reman engine from ford so no custom machining was done.. im gonna do this how does it sound
start it rev it up and down from idle to 2500 for about 2 mins or so to chek for leaks and noises then drive it around the block one or 2 times chek for overheating and oil press.. then get on the open road and let the rings seat
get on a slight hill in 3rd at about 2000 rpm to load the engine .. then slowly i will begin to shift higher rpms.. like 4000 will be max till 500 miles then after oil change i will bounce it off the limiter and drive it like i will be for the next years to come
how does it sound?
btw how much oil press should i be seeing from idle to 5000 Rpm??
how does it sound?
#25
If your engine was run in on a dyno (assuming it was given you gave the torque numbers) and the break-in oil changed the rings are seated. They were seated before the first full on dyno pull. I'm telling you I've built engines in the morning and raced them that night. If the engine clearance is right, has the right cyl bore finish it doesn't know the differance in 1 mile and 100,000 miles.
#27
how does it sound?
how does it sound?
#28
dont rev it too high...i would say half of the redline for at least 500 miles. also DO NOT put synthetic oil in while breaking it in. it is important to "wear" while breaking it in. this will make the rings and cyliners not burn oil later.
No links to place of business please! thanks
#29
If you want the car to be "healthy" for a long time, I wouldn't beat on it! You don't need to do anything special to break it in, just drive it in the same manner you would any other car.
no links to place of business please
#30
Have a great <a href="http://www.mustangbrakeparts.com"> Mustang Parts </a> Day.
